straight piping
Cat cutting might help... but the muffler has no added restriction. All you're going to do by removing the muffler is just make the truck louder... and I hated the sound of mine when I tried it.
Without looking at the performance of your truck with regular gauges or a scan gauge - like AutoEnginuity, Torque Pro, or Dash Command... you're coin-tossing with a keyboard and a cutting wheel.
Received 3,110 Likes
on
California prepped f250's and F350's don't have glow plug relay's, they have glow plug control modules, but that doesn't mean they also have catalytic converters.
It used to be hypothesized that the rhyme and reason was the L99 and up 7.3 PSD's with automatic transmissions were catless, but the manual transmission trucks came with cats. However that was disproved a couple years ago.
Then recently (the past year?) someone posted information that gave proper rhyme to the reason Ford put cats on some (very few) L99 and up trucks, but not others (vast majority).
I just wish I had remembered to save the info he posted so I could post it here now.
Damn CRS syndrome......sigh.
Stewart
PS - The E99 trucks were different. I believe they all had cats.
ford sells a cat delete pipe that fits in between where the cat goes . I had replaced mine but have since gone with a whole new exhaust with no cat a mbrp 4in it is much better. I don't know where my pipe is I should have kept it I will look for it. I know I kept the cat just in case but we don't even have emissions in my county on anything!!
Agreed, In addition be prepared for the weight of the stock mufflers. Them things are heavy and can break a finger. Did two mufflers. Cut the things apart (no cats here though)
Ended up putting pass through silencers on both trucks ( 3 1/2" ) after we got sick of the noise. The silencers brought the noise back down. With the silencers it is normal noise at normal driving. Under heavy load it is slightly louder than stock.
Got the pass thru silencers from summit racing. http://www.summitracing.com/parts/wlk-24216
on
For 7.3's, it's not being California prepped that determines if it has a catalytic converter or not.
Stewart
Stewart
here on the east coast we don't see any of those silly pollution controls on our pre 04 diesels.
although i did once see a cali IDI, and a cali early 90's F3-Superduty-460 with cats come through the body shop to be straightened after fender benders. .
My old 2002 F250 with the 7.3L PSD (now my daughters truck) is a California prepped truck and it came from the factory without a cat.
Just as aside, all 7.3L powered Excursions are the same as the California prepped trucks with 7.3's. None of the 7.3L PSD Excursions came with catalytic converters.
The gas Excursions and the 6.0L powered Excursions did, but not the 7.3's.
Stewart
Stewart
Received 3,697 Likes
on
my '97 picked up about 2 mpg with 4" strait pipe exiting in front of the tire. I also put the 6637 filter in at the same time.
it is loud and when towing it is really loud. I wear ear plugs when towing it is so loud.
my '99 I have no idea on mileage or performance as I put 4" strait pipe on it before I ever drove it but it is loud, not as loud as the '97 as the '99 is long bed with a service body so I don't hear it as much.
had I known how loud it would be I would have out a full flow resonator in the '97.
the load in my signature is 10 hours of wearing ear plugs to get home!
I cut the guts out of a muffler and put it on my fathers truck, actually has a nice sound to it and is still quiet in the cab. I have a straight pipe with a homemade thin wall 8"x24" echo chamber with a turn down before the axle that sounds mean when you lay into it, gotten many compliments. It'll make your ears bleed yanking a load for extended periods though. It sounds like a common rail killer, though it's not.
quoted from TJC TRANSPORT
[here on the east coast we don't see any of those silly pollution controls on our pre 04 diesels.
my truck is a early bird 6/98 ordered from va. built in Kentucky 6-sp manual it had a cat factory I know because I ordered the truck new and I still have it ! the truck not the cat. only the one glow plug relay nothing else
2003 6.0L PSD's were all sold with pollution control devices too.
The east coast is not exempt from federal government requirements and standards.
Stewart
