1991 F150 won't shift into Low Range.
I have a 1991 f150 5.8L. It shifts into 4HI just fine but it will only shift down to 4LO when the engine is off. I've already messed with the linkage and concluded that is not the problem... when I turn the engine off and shift into 4LO and start the engine, it works fine. Is that process bad for any of the components? Any info will help. Thanks!
How are you trying to put it into 4lo. in gear in park ?
Truck must be at a stand still.
Push on the brake.
Put truck in Neutral
to shift from 4hi to 4lo you have to push down on the stick then shift from 4hi to 4lo
if truck still will not go into 4lo put it back into 4hi put it in gear roll forward a little bit and put it in neutral and shift again from 4hi to 4lo.
Push on the brake.
Received 3,110 Likes
on
93flareside 7.3 swap
11-04-2018 10:17 PM
Highcountry30
11-06-2016 11:36 PM
