Pennsylvania Chapter Join Chapter, Leader: liftnw8z
Good Old-Timer mechanic for Carb/Vacuum issues (86 6cyl) in PA?
Old 03-25-2014, 03:54 AM
WalterRoad's Avatar
WalterRoad
WalterRoad is offline
Does anyone know of a good place to go for carb/vacuum issues in the central PA area (anywhere between Stroudsburg and Lewisburg or even close)? I'm actually from CT, but have family in PA so I'd be willing to travel to the PA area too...
Anybody know of someone who's familiar with the older factory setups, I'm as good as any to swap parts, I'm hoping to find someone who's good with these older vacuum and carb'd setups for some fine tuning. The van is my everyday/everything truck. Any pointers would be very much appreciated, thanks!
Old 05-23-2014, 01:48 PM
Gettysburg150's Avatar
Gettysburg150
Gettysburg150 is offline
What kind of problems are you having?
Im no expert in the carb department, but I know ethanol fuel sucks (most everything around me is up to 10%) and vacuum lines like to crack and break.
Old 05-23-2014, 03:38 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
It's getting tough on some of this stuff. Once the current independent shops finally hang it up, forget it. You're on your own. The good thing is, the web sites that weren't around 20 or 40 years ago will teach you as much as you can handle about carb tuning or anything else. You need a tach and a vacuum gauge in addition to the usual tune up stuff.
Old 05-27-2014, 01:43 PM
quaddriver's Avatar
quaddriver
quaddriver is offline
well the first thing you can do it locate, photograph and post your VECI label (vehicle emissions control information) it lists every hose on that motor as installed for that cert, by the factory. Many a time I have used it to verify equipment, problems, restore 'expert' repairs.
as someone mentioned, parts are going to be hard to have...too many of these things have been smooshed and sent to china....
Are you having EGR or spark porting issues? (most common on the I6)
where is said label? Can be on the hood, air cleaner or radiator valence.
If you toss out a vin we might be able to work backwards and find a 'generic' one online.
Old 06-01-2014, 04:33 PM
GLR's Avatar
GLR
GLR is offline
Where in NY are you located?
I'm an old-timer mechanic but, not saying I'm good.
Old 06-17-2014, 07:47 PM
amtrakjoe's Avatar
amtrakjoe
amtrakjoe is offline
Good Mechanic
Hello, If you're making your way to Pennsylvania you can make a turnpike stop at Bowen carbouretor. Look them up on the internet. They are in Bucks County Pennsylvania just north of Philadelphia. They are wonderful mechanics. Call ahead of time. - Joe
Old 06-30-2014, 06:55 PM
dustybumpers's Avatar
dustybumpers
dustybumpers is offline
86 is a feedback carb, check your engine codes first, you may have a sensor problem, not a carb problem.
Keymaster
01-01-2018 10:23 PM
Locorotc
16
12-05-2011 10:34 AM
brianlr77
1978 - 1996 Big Bronco
04-17-2007 08:07 PM
navyflyinggreg
11-27-2004 10:25 AM
Quick Reply: Good Old-Timer mechanic for Carb/Vacuum issues (86 6cyl) in PA?
