P0171 code only. Any ideas?
My daughter returned from college with her 2000 f150 4.2 idling and running rough on acceleration. It is throwing a P0171 code only. I replaced the isolator bolts/plenum gaskets four years ago because of a P0171 & P0174 codes.
So far I have replaced the MAF, new PCV valve and elbow, checked all obvious lines for vacuum leaks (though I suspect a leak somewhere still).
Also, a quick check of the plugs show some lean color/deposits on the drivers side only. Any thoughts or troubleshooting I should try next?
Thanks,
'bob
Thanks,
'bob
Thanks,
'bob
Thanks,
'bob
