Can't find a socket to fit D60 pinion nut?
I want to change my donor D60 pinion seal as a part of its refurbishment prior to swapping it in.
There is a .010" difference between 33mm and 1-5/16" socket but I'm betting on the 1-5/16" being the correct size. But that's not my problem at the moment...
I can't find a socket thin walled enough to fit inside the yoke. I picked up an impact socket (from Northern Tools) and it won't get in there at all. A "Martin" brand will get about almost half ways on before its outside diameter stops it from going in further.
This nut is to be torqued to about 230 ft/lbs, where do I find a socket that will fully engage the nut and stand up to this?
dobber97
09-05-2009 08:35 AM
