Center Brake light
Old 05-28-2014, 12:58 PM
roperchick's Avatar
roperchick
roperchick is offline
Center Brake light
My center brake light went out a month ago. Thought it was the bulb so replaced that, still didn't work. Checked the fuse and its not broken so my guess was electrical?
Hasn't come on once that I know of but I was randomly walking behind my truck and the light was on. Truck was off lights were off and key wasn't in the ignition.
Went and turned my truck on and turned the lights on and the cbl stayed on. When I switched my lights off it went out and stayed out.
Now I'm definitely thinking wiring but not sure where to start fixing?
Oh and it's a 1990 F150 XLT
Old 05-28-2014, 04:49 PM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,683 Likes on 1,359 Posts
Take the sill panel off and pull up the mat on the driver's side along the seat area and up the driver's side between the back of the door and the driver's side of the rear window. The wiring goes along this area, and sometimes corrodes and shorts out in behind the seat and along the bottom of the door sill area.
The wire you are looking for is a lightgreen wire. It comes right off the brake light switch on the pedal arm. It splits and goes to the steering column and straight up to your rear brake light. It also splits off and goes to the cruise system if you have that.
Old 09-03-2014, 11:38 PM
roperchick's Avatar
roperchick
So turns out they didn't start putting cbl in these trucks till like '96 and mines actually the cargo light. Ha. My bad. I did fix the wiring though and it works now though.
billjackson5000
1999 to 2016 Super Duty
12-14-2023 06:00 AM
island eddie
Electrical Systems/Wiring
11-17-2017 09:33 PM
thordehr
02-07-2015 11:19 PM
harvey7212
1983 - 2012 Ranger & B-Series
07-22-2006 12:37 PM
Brilac
02-16-2005 09:55 AM
Quick Reply: Center Brake light
