Axle Swap
on
I was going to ask the same question. Keep the 10.25 axle as they are nearly the same as the 10.5. Use the disc rear brake from the 10.5, but use the rotor from the Econoline E-250/350 equipped with a Dana 60. You would have to measure to see if they use the same size rotor. This will keep your wheels the same 8X6.5" as your front axle. The Super Duty uses a 170mm wheel which won't fit the front.
Jayy
04-06-2015 03:20 PM
Twistedtesty
05-24-2010 09:58 PM
MustangGT221
01-19-2005 04:34 PM
RTM
05-25-2004 04:37 AM
