desperate held needed 460
Old 05-27-2014, 03:48 PM
gav2606's Avatar
gav2606
gav2606 is offline
hi all..i live in the uk and have a e350 cabriolet fifth wheel pick up..out of the blue it cut out..pulled over and restarted but it just keeps cutting out..rough idle sometimes but sometimrs runs like a clock..changed fuel pump..coil..carb..checked fuel lines..cleaned tank..changed plugs leads and cap..rewired coil..its got a dura spark 11 box..i believe it has a oil pressure safety system and fuel cut of but seems all ok..it does jump and splutter it just dies but still showing a spark and fuel..HELP please
Old 05-28-2014, 10:25 PM
fuzzybob's Avatar
fuzzybob
fuzzybob is offline
Hello gav, Did you check the wires to the pick-up coil in the distributor? They flex as the dizzy advances and retards and sometimes crack and make a dodgy connection.
Good luck with it, Fuzzy
DntRmmbr
01-31-2011 09:38 AM
Dustin460
08-08-2009 03:09 PM
johnrogers
1999 to 2016 Super Duty
02-29-2008 01:15 PM
Canadianice
Bronco II
22
05-07-2007 06:22 PM
jpm2591
1983 - 2012 Ranger & B-Series
04-30-2004 08:49 AM
Quick Reply: desperate held needed 460
