Sponsored by: Real Truck
Miss in engine
Old Feb 28, 2008 | 05:45 PM
johnrogers's Avatar
johnrogers
Miss in engine
Hello, I am in a at a stand still with my ford F350 with a 460 engine. After changing inline fuel filter, new spark plugs, spark plug wires, coil, taken it to 4 mechanics and still have a miss when under pressure (pulling my 5th wheel) Does any body have an Idea what it might be?
all help and comments will be appreciated.
John
Old Feb 28, 2008 | 05:48 PM
redford's Avatar
redford
FTE Leadership Emeritus
Oh yes.
You probably have a clogged catalytic converter. Disconnect it and take your truck for a spin. You'll know right away if this is the problem.
reddogracing's Avatar
reddogracing
seems to easy, but mine did same. Did not notice miss at idle only under load. Seemed Ok other then that. I crossed two plug wires. Guess they were close enough that it only showed under pressure, worth a check anyhow.
Old Feb 29, 2008 | 07:10 AM
johnrogers's Avatar
johnrogers
thank you I will try, better than removing the fuel tank to check the fuel pump
Old Feb 29, 2008 | 09:48 AM
krewat's Avatar
krewat
Just get a fuel pressure gauge with a long enough hose, and drive it with the trailer on it and watch the pressure when it starts to miss. You don't need to drop the tank
I'd also check the MAF if you have one - cleaning it might be in order.
Old Feb 29, 2008 | 10:11 AM
johnrogers's Avatar
johnrogers
miss in engine
Do you put the hose in the gas tank? we have dual, which one if thats how it's done. Will that tell me if its the fuel pump?
Old Feb 29, 2008 | 10:22 AM
krewat's Avatar
krewat
There is a schrader valve (tire valve) on the fuel rail on the engine - you hook up a fuel pressure gauge to it to check what the fuel pressure is. If you get one with a long-enough hose, you can slip it under the wiper arm, and drive around with it in plain sight.
That way, when it's missing, you can see if the fuel pressure is too low.
Old Feb 29, 2008 | 10:29 AM
johnrogers's Avatar
johnrogers
THANK YOU SOOOO MUCH, OFF WE GO TO GET A GUAGE
John
Old Feb 29, 2008 | 01:15 PM
redford's Avatar
redford
It's probably not the fuel pump, since you have 2. Switching to the other would make the problem go away if it was a fuel pump.
It could possibly be the fuel filter.
