55 f100 brake light stays on
Old 05-22-2014, 01:34 PM
mdrozell55f100's Avatar
mdrozell55f100
mdrozell55f100 is offline
My 55 f-100 brake lights were independently staying on. Anyone with thoughts as to what the problem may be will be appreciated?
Old 05-22-2014, 02:28 PM
raytasch's Avatar
raytasch
raytasch is online now
Believe Nothing
Typical bad pressure switch. They go bad one of two ways. Too much pressure required to turn on or they stay on.
Edit: And, oh yes, welcome to the forum.
Old 05-22-2014, 02:31 PM
mdrozell55f100
Thanks, I'll check that out!
Old 05-22-2014, 02:33 PM
GLR's Avatar
GLR
GLR is offline
Ditto on the switch and ditto on the welcome. You can use a test light to see if there is voltage on both sides of the switch. (There shouldn't with brakes off)
Old 05-22-2014, 06:45 PM
The Horvaths's Avatar
The Horvaths
The Horvaths is offline
Or a bad residual pressure valve in the MC. Popping a bleeder would tell you if there's significant pressure in the lines.
h089421
07-27-2011 04:06 PM
john smith jr
08-26-2010 10:45 PM
64fordf100292
15
12-12-2007 12:02 AM
55ford239
05-05-2005 02:58 PM
leonharu
06-26-2002 10:03 PM
Quick Reply: 55 f100 brake light stays on
