Typical bad pressure switch. They go bad one of two ways. Too much pressure required to turn on or they stay on.
Edit: And, oh yes, welcome to the forum.
Ditto on the switch and ditto on the welcome. You can use a test light to see if there is voltage on both sides of the switch. (There shouldn't with brakes off)
