cannot fill past half tank. 79 bronco
Ok here is the scenario. I cannot fill the tank past half. It does not really matter if it is empty or at 1/4 it will not let anymore than a squirt in.
Would the likely culprit be the vent tube on the side of the fill neck or at the top of the tank?
Tank is clear, new sending unit and both fill hoses all from JBG. It is a 25 gallon tank.
True
Well both vents are clear, went to fill the tank last night. It had about a quarter in it. Sadly only took 11 gallons......and it took for ever.
There is a little kink in the big fill hose, I believe this is where my issue is. After the weekend I am going to cut the hose and put a piece of exhaust pipe in there that I can flatten a little to clear the frame and see if that takes care of it.
Old Brown Truck
10-31-2015 10:30 PM
