Blown Spark Plug/Ignition
There is a rumor? going around about the spark plug/boot and ignition blowing out of the cylinder on the 2003 F250 Super Duty 5.4L. I have almost 100k on the engine, but changed the plugs to Bosch made in Germany plugs. I did notice that the threads were longer than the Autolite than came from the mfr. I have had no problem. Is there a problem with this happening?
The issue of blown plugs tends to be more related to the head and not necessarily the plug itself. Our Modular motors do not like any brand other than Motor Craft or Autolite equivalent version. Believing more threads will reduce or eliminate this doesn't hold water.
It would seem many, many blown plugs are the direct result of plug hole damage created when they are installed. While it's 100% possible this can be a spontaneous thing most often its a heavy handed mechanic cross threading or over tightening the plugs.
I've always used Motor Craft, a dab of nickel-based anti-seize on the threads and slowly pull them up to 21-23 ft/lbs, stopping once the torque wrench clicks. So far I've been trouble free.
lincolnshibuya
1997-2006 Expedition & Navigator
08-09-2017 09:24 AM
tatonka
08-13-2006 05:39 PM
