Simple, probably stupid question
Received 3,779 Likes
on
May I hijack and ask if folks would buy an e99 again if they had the chance? I'm considering it for a part time use truck because there are some deals to be had out there.
Frank >> you've done a lot to yours to get it where you want it, including a PCM change.
Wondering if a stock version of this truck would do the job. I'm not in a hurry anymore to get up Stevens Pass at 55 with a 31' bumper pull. 40 is ok.
on
no complaints from me, mine has over 330,000 miles, 4 inch strait pipe exhaust and 6637 intake are the only mods on the truck. it is only 2 WD and has a 6 speed trans. without towing here in the mountains I get 20 mpg.
with the service bed loaded with tools and equipment I am at about 10,000 lbs I can top out "sunset point" on I17 going north out of Phoenix at 90, it is 6-7% grade for 6 miles.
when I go to the mine and bring the bucket back I have my car hauler, 3,000 lbs and the bucket 6,000 lbs and I pull the grade on Iron springs road at about 40 mph it is 6+ % grade and 50 is the speed limit because of all the corners
as for the right parts! if it is something that is different than all the others I am most likely getting it from ford and they run the vin number in the parts computer so I have never gotten the wrong parts (yet)
fishforlife2007
18
02-15-2015 02:31 PM
