wierd part needed
Old 05-15-2014, 02:14 PM
C-700's Avatar
C-700
C-700 is offline
Question wierd part needed
Here is another hard one. I need a spring clip for a bolt on the hand brake drum assembly. It holds the headless bolt 7EQ2616 and stops it from turning. Green Sales has the bolt which I already have but I can not find a part number for the clip and Green Sales said it does not come with the headless bolt. It screws into a TGAA2621A I am working on a C-800 hand brake 10 1/2 in drum. Any help would be great. Thanks
Old 05-16-2014, 10:55 PM
C-700's Avatar
C-700
C-700 is offline
are there no takers on this part problem? Any ideas were else to look?
Old 05-17-2014, 01:10 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
OK, I looked up your part numbers in the Parts Catalog. Looks like the headless bolt has a hole in it for safety wire, just like all the headed bolts on the other models. I don't know what clip you're looking for. It's not shown in the diagram, but neither is the safety wire in this drawing.
Name:  Pages from Illustrations Catalog_Searchable.jpg
Here's a drawing of the another headless bolt with safety wire for your reference.
Name:  Pages from Illustrations Catalog_Searchable-2.jpg
Old 05-17-2014, 03:48 AM
big job's Avatar
big job
big job is offline
I need to know the year of the truck, to know if it is internal or external
style drum?. I have a C700 and its external drum.
Old 05-17-2014, 08:56 AM
Jolly Roger Joe
Big Job, the part numbers he gave are shown below .
7EQ 2616
48/ Parking Brake Band Anchor Clip Adjusting Bolt - THQ, Q, QH, #QH, QHS, QW, QHW, QSW, Z, ZW 5/16"-18 x 1 3/4" headless
TGAA 2621-A
53/56 Parking Brake Anchor Bar - QH, QHW (except T/A) (MS, QSW Q with tandem axle with tandem axle & auxiliary transmission with tandem axle 9 27/64" long
On a side note, I converted both my Text and Illustrations Catalogs to searchable PDFs. Makes looking for numbers much faster.
Old 05-17-2014, 09:20 AM
C-700's Avatar
C-700
C-700 is offline
It has an external drum. The bolt is headless and has a slot cut into the top. The spring clip fits in the slot and then pushes though the other small hoes in the bar to keep it from turning.
Old 05-17-2014, 09:29 AM
harleymsn's Avatar
harleymsn
harleymsn is offline
How did you do that?
Old 05-17-2014, 09:39 AM
Jolly Roger Joe
I downloaded a free app to remove the restrictions on the files. A-PDF Restrictions Remover. http://www.a-pdf.com/security/restrictions_remover.htm
Then I used an app I have for work, eCopy PDF PRO Office to convert the files to a searchable format.
The conversions weren't perfect, but I'd say I can find 90% or better by searching for the number.
Old 05-17-2014, 09:40 AM
C-700's Avatar
C-700
C-700 is offline
I am sorry, the bolt passes through the bracket on the brake shoe and screws into the bar. The small holes that the clip fits into are in the bracket on the brake shoe. There are three hole in the bracket for the brake shoe, center hole for the bolt to pass and two smaller holes for the ends of the clip to fit into.
Old 05-17-2014, 11:56 AM
Jolly Roger Joe
Have you ever seen this clip you're referring to? It's not in the parts manuals. The diagrams I posted show where the safety wire runs through the hole in the bolt to the holes in the bracket to keep the bolt from turning.
Looks something like this, except I have the spring on the outside instead of the inside of the bracket.
Can you post a pic of your headless bolt?
Old 05-17-2014, 12:29 PM
C-700's Avatar
C-700
C-700 is offline
That is the idea only no head no whole and just a deep slot. I will try to post a picture.
Old 05-17-2014, 12:51 PM
Jolly Roger Joe
OK. Safety wire through a deep slot would accomplish the same end. It's just there to keep the bolt from turning once you have the adjustment gap set. The slot is probably for turning it with a screwdriver?
Old 05-17-2014, 01:18 PM
C-700's Avatar
C-700
C-700 is offline
True but I am a nut about finding original and I want one or at least a picture of one. I suppose I can make one. I don't think they worked real good.
Old 05-17-2014, 01:20 PM
C-700's Avatar
C-700
C-700 is offline
What is the transmission for?
Old 05-17-2014, 01:31 PM
Jolly Roger Joe
The pic is of the T-9 in my '51 F4.
Quick Reply: wierd part needed
