Coolant flush DIY procedures on a 460?
Searched, but only found info on diesels.
Would like to perform a coolant replacement/flush on my truck since I don't know when it was last performed. Will also be replacing all hoses (radiator, heater), thermostat, and radiator cap as they appear original (1992).
What are the procedures for performing this on my own?
I've read about using only distilled water but wasn't sure if this was only true for diesel engines.
Should back flush kits that that tap into heater hose be used?
How about using the flushing chemicals?
Thanks
Thanks
When I did my thermostat a couple months ago I pulled the upper and lower hoses off got the hose and 4th water thru the radiator from top to bottom and then bottom to top. U pulled the thermostat out aand stuck the hose in the thermostat housing and let it run until clear. Then I took the water house and stuck it in the lower radiator hose and let the water come out of the thermostat housing messy yes but effective. The only thing I didn't do was start it up and turn the heater in to flush the heater core. I finished put it all back together and ran it for a day and drained it all again running the heater while I was driving and refilled.
Disconnecting & flushing at the heater hoses (as in the Cap-A-Radiator link), bypasses the thermostat.
Thanks
Thanks
Unlike diesels (many many WRONG things can happen after a flush), gas engines are fairly tolerant --one area to consider: if the water you're using is hard (5 grains or so), high ph (greater than 8), then I'd look for water containing less calcium/mag (and closer to neutral) or you're just asking for long term trouble...........
90pioneer
10-30-2011 09:35 AM
grnburg
07-16-2006 09:27 PM
bpsigchi
10-11-2005 12:49 PM
gube
12-19-2003 08:03 AM
