Quick Release Cap Bolts?
I have heard of guys not using all 15 bolts to keep the top on. unsure if this is an option for you or not and I wouldn't necessarily advise this, just saying is all. I imagine if you could also fashion some sort of bar that would run down the length of the top you could probably get away with less bolts and still maintain enough holding strength.
I tried the QR pin method years ago. I tossed the idea in favor of using just four bolts. It takes a little more time but to use QR pins properly you would need to fabricate some sort of tabs on the bedrails and punch holes in the top flange to allow the pins to function as pins. (Relying on the locking ball on a QR pin to hold the top down is truly ill-adivsed and will not hold the top securely enough to keep it from rattling and scuffing the bedrails and seals).
I don't keep the plastic trim anymore, too much of a pain. During the summer I use 3 bolts on the bed rail each side. I keep all original 5 tamper proof bolts in that go in the top and the sides because I have the bit to remove them and I put it in a drill to remove and place them back in. Legit takes 30 seconds to remove all 5 with the bit in the drill.
Alan'sExpy
1997-2006 Expedition & Navigator
07-29-2007 09:21 AM
