HELP 09 6.4L Died without warning!
Driving down the road and it sputtered, smoothed out, then died. Good strong crank, no start. Although I know that 6.0L well, I'm a stranger to the 6.4L. Here's the codes.
Fault log report generated by Torque for Android
Vehicle VIN: 1FDAF5HR9AEA*****
Vehicle Manufacturer: Ford
Vehicle Calibration ID: 8U7A-14C20
Current Fault Log
ECU reports no current faults
Pending Fault Log
P0087: Unknown code - More information may be available on the web
Historic Fault Log
ECU reports no historic faults
Other discovered fault codes
(possibly pending, current or manufacturer specific)
B2900: Unknown code - More information may be available on the web
U2011: Unknown code - More information may be available on the web
U0115: Unknown code - More information may be available on the web
U0155: Unknown code - More information may be available on the web
U0100: Unknown code - More information may be available on the web
U0101: Unknown code - More information may be available on the web
P0278: Cylinder 6 Contribution/Balance
P2291: Injector Control Pressure Too Low - Engine Cranking
P1260: [Chrysler] Last Test Failed Failed SCC ENTER:More Info.
[Ford] Theft Detected - Engine Disabled
[Mazda] Anti-Theft System Signal Detected - Engine Disabled
[Dodge] Last Test Failed Failed SCC ENTER:More Info.
[Jeep] Last Test Failed Failed SCC ENTER:More Info.
P215A: Unknown code - More information may be available on the web
P1000: [Ford] OBD-II Monitor Testing Incomplete
[Mazda] OBD II Monitor Testing Not Completed
End of report.
Current Fault Log
Pending Fault Log
Historic Fault Log
End of report.
Thanks for the response. I'll check into that on Monday. It appeared the fuel flowed freely through filter. So that P0087 does not point to injection pump troubles? What a relief!
They look fine. After checking it, I turned the key on and listened to the pump. Sounded normal. I could hear the air being purged from the filter, then as it came through the pump. After a while it bubbled violently in the tank until the air was all pushed out. I'm of the mind the lift pump being good ... or does that not confirm it?
