04 to 08 motor swap, p0174 code, help snow is comming?
has anyone swapped a later model motor into there chassis, I swapped and 08 into mine and i cant get rid of the p0174 code. I have checked for vac leaks, swapped maf, intakes and replaced gaskets, o2 sensors, cats, replaced coils, done a fuel injector leak test, the bank one trim is good where the bank two lttrim is out at 30%, I've been hitting a brick wall and cant get around it. I asked my ? on that just answer site and the guy claims the cams are diffrent and is what is causing the problem? seems like it would do it on both sides.
Any ideas?
Any ideas?
hmilycar
1983 - 2012 Ranger & B-Series
07-09-2015 11:11 AM
Reed
32
07-02-2010 10:53 AM
almus
06-09-2007 01:49 PM
