Injector line.
Old 05-09-2014, 12:19 AM
rwelli1001's Avatar
rwelli1001
rwelli1001 is offline
Injector line.
Holy cow. Had my Injector pump off for return line fittings and O-ring replacements. When I was cleaning up the pump and injector lines I noticed some wear on the steel line for cylinder # 8. A hole almost rubbed half way thru the steel line. Source of problem was the Cruise control cable was routed over and laying on the steel line. Over time the ribbed cable sheath had acted like a saw and was cutting the line in two. (Not leaking yet.)
I rerouted the cable to go under the injector line.
Local International dealer can get me the one new steel line for about $140.00. and wait time.
Hydraulic shop across the street from the dealer can make me one for about $60.00 when I take the bad one in for a pattern to follow. Same day service.
Posting this for others to check on their rigs before they have same problem.
Old 08-28-2014, 10:13 PM
rwelli1001's Avatar
rwelli1001
Ended up buying a new line. Hydraulic shop was not able to duplicate the flared ends and I did not want to risk a weld repair.
Old 08-28-2014, 10:27 PM
sjwelds's Avatar
sjwelds
sjwelds is offline
I weld hydraulic lines that see upwards of 2500 psi frequently. So far don't know of any problems.
JM2CW
Old 08-29-2014, 11:02 PM
Sycostang67's Avatar
Sycostang67
Sycostang67 is offline
Did you check salvage yards? I scored a complete set of lines for $11. They came in handy when I had my 86 as the PO had cross threaded the #8 line and ruined the injector threads and the flare on the line.
LSO1123
08-23-2011 06:30 PM
eatont9999
WTB - Parts & other
06-26-2011 11:27 AM
Franklin2
18
09-19-2009 01:12 PM
sampatton
06-29-2007 01:53 PM
slspokane
10-23-2006 08:50 PM
Quick Reply: Injector line.
