transmission question
Old 05-08-2014, 12:18 AM
rockin300's Avatar
rockin300
rockin300 is offline
Ok my truck only does this off and on its a 1994 f150 4x4 with the inline 6 .....it seems to wanna shift hard like they do when the fuse for the radio and speed sensor goes out but the fuse is fine and im just wondering if the shift sensor could be getting weak
Old 05-08-2014, 01:04 AM
MFJ's Avatar
MFJ
MFJ is offline
Try wiggling the connector for the MLPS, on the driver's side of the transmission. If that makes it work better, next step might be trying to clean the contacts, or a new MLPS.
Newer ones (95-up) have a better design for the plug. I think there is a harness to retrofit the newer MLPS and plug to the older trucks.
Old 05-08-2014, 07:35 AM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,164 Likes on 919 Posts
Your transmission is computer controlled. Any malfunctioning sensor can trigger the transmission into limp mode, with or without a Check Engine Light. Check for codes.
Old 05-08-2014, 08:15 AM
rockin300's Avatar
rockin300
Ok thank you guys my 93 didnt do it at all
Wrknman
1999 to 2016 Super Duty
07-21-2019 09:04 AM
Flatbed 97
Electrical Systems/Wiring
03-10-2018 04:46 PM
nikiter
2004 - 2008 F150
01-10-2014 09:45 AM
ktm25094
1997 - 2003 F150
09-07-2011 01:53 AM
scojen
04-27-2009 11:02 AM
Quick Reply: transmission question
