Fuel bowl re - O ring?
I have a fuel leak on my 2000 Ex, 7.3l. I'm guessing it is at the fuel bowl. I replaced the drain valve o-rings about 5 years ago. Would you guys suggest I purchase a kit to replace all of the fuel bowl o rings and seals or just do the drain valve o ring again? The truck has 210k miles on it.
Thanks guys. I will order the bowl rebuild kit and take it from there. If I remember correctly, it was a fairly simple job to do the drain valve o-rings. I'm sure doing the rest of them won't be a big deal. Last time I had to do them it was in the middle of the winter, no garage. At least the weather is more agreeable now
11-07-2009 12:22 PM
schlepprock250
13
12-02-2008 01:37 PM
