1992 ford f250 diesel E40d
Old 05-04-2014, 12:55 AM
Pstlpete's Avatar
Pstlpete
Pstlpete is offline
Every time I disconnect the battery terminals on this truck, the transmission computer goes into safe mode and it shifts into the gears early at low rpms. The motor actually starts to struggle. It goes thru all the gears to OD and then changes back and forth in and out of OD. I turn OD off but it still goes thru the gears fast in all the other gears aswell and it doesn't sound right. I've been having other issues with transmission sensors on this truck which I've replaced over time, but I'm thinking the computer on this truck might be an issue as it takes a few hundred clicks for the computer to go back to shifting normal again after the terminals are disconnected.
jeramy
01-18-2010 09:41 PM
crm318
05-03-2006 12:56 PM
Mwachel
Modular V10 (6.8l)
05-25-2004 07:44 PM
jtilley
01-26-2004 09:13 AM
padutch
06-04-2002 07:41 AM
Quick Reply: 1992 ford f250 diesel E40d
