Loose Parking Brake Cable along frame rail
Hi Fellas, my parking brakes haven't been working well for a while. I was looking everything over today and I see that the portion of the brake cable along the frame rail has some droop in it. It needs to loose about 3/4" to gain tension again.
I went down to the parking brake lever on the rear end and both sides still feel pretty springy, giving me the impression that nothing is broken internally on the show assembly. Sound right?
I'd like to avoid pulling the whole rear end apart to inspect the internals and I thought I'd start here.
I know I can adjust the parking shoes by using the adjuster but 3/4" seems like a lot to be compensated for through the adjusters, no? I'm trying to figure out how I gained this much slack in the parking brake assembly. Any ideas?
Just to give a little history, I broke the upper cable about a year ago. The cable stopper broke right off the end of the cable at the pedal. I replaced that cable and all was well for about six months. Now the pedal goes to the floor (2/3 before) and it doesn't hold. The cable does get tighter but it's obviously not grabbing at the moment.
WET BLANKET ALERT!
Sorry, but I bear bad news. The cable is fine - it's suppose to be that way. The problem is very likely the rusted lever on the end of the cable (photo - top right). I could not exercise the lever even after I had it on the bench - it took a mallet and a vice to get it to move. It's a bugger how much carp you have to remove to get to it, but it's a train wreck to re-install. It's a good idea to inspect your brakes and grease your slide pins. When you inspect, the most common failure is siezed slide pins on the calipers and the symptom is obviously-excessive wear on the inside of the rotor.
I have auto, so I didn't realize my park break was bad until after a separate brake issue flared up (literally).
The cables do stretch a little bit over time. Not right but I have tied a knot in the cables before to take out some slack, I've done it to a few of our trucks and haven't broken a cable yet because of the knot.
But I agree with the others, check over everything else before trying to take cable slack out.
When I put the parking brake pedal to the floor about 1" of cable gets pulled from each side the Y connection on the frame rail. So it appears everything the parking brake assembly is working correctly. I guess the next step is to pull the rear wheels and inspect the brakes. Removing the parking brake assemly is a PIA with the clutch pedal in the way. I thought that was going to be where the problem was.
Have same issue. I replaced the front part/peadl cable, last year, but still takes the pedal to the floor to "set" any brake. With boat trailer at ramp, with the angle, theres enough weight pulling truck to allow it to slip backwards. No "slop" at cables though...and cant see anywhere to adjust...calipers at rear.
I think I need to replace the long cable that runs from the Y to the front. I adjusted the brakes as instructed. I can apply both rear brakes with the adjusters.When I put the parking brake pedal to the floor it doesn't quie pull far enough. If I pull on the cable from below another inch the brakes get applied.
