Stuck horn 2000 F-250
Horn isn't working found fuse blown. Replaced fuse and horn stays on. Swapped relays still stays on. With fuse out pressing left side of horn cover on steering wheel I can feel/hear relay click. Pressing right side not so much. Thoughts on what and where to check? Is there a way to disconnect the horn buttons on the steering wheel? Would that help pinpoint the problem? Thanks for any help.
I believe that there is a horn relay, if there is remove it. Or disconnect the wiring from the horns until fixed. The horn button wire must be shorted to ground. The button works by grounding the horn circuit which allows a buzzer like relay to send pulses of electricity to the horn. It is most likely happening in/or around the steering column.
