04 excursion humming/vibration in overdrive
i just bought an 04 excursion with the 6.0 diesel. i took a trip to vegas and noticed a humming/ vibration about 55-65mph only in overdrive. i have checked u joints and they look good . the x does have a small lift its the bracket kit with stock springs. what gets me is i dont notice it driving in town only in overdrive at highway speed any help would be greatas im new to the ford world thank you
Also if bearing was replaced previously the driveshaft might of not been reinstalled properly and its causing the vibration.
I recently had this issue and same symptoms.
How do you get a Torqueshift into overdrive?
I'm guessing you mean when it reaches the 5th gear. I would not rule out exhaust or drone. You'd be surprised how you can feel harmonic vibrations. If you use Tow Haul mode and don't get fast enough for it to shift into the 5th gear, probably in the mid 50's, if you don't feel it, but then shift into the 5th gear and you do, and at the same speeds I'd think you have a drone or harmonic issue going on. Driveline issues won't usually change at constant speeds.
