2003 Expedition towing capacity: 4.6 vs. 5.4
Old 07-04-2003, 11:06 PM
anglerx's Avatar
anglerx
anglerx is offline
Question 2003 Expedition towing capacity: 4.6 vs. 5.4
What is true difference in towing capacity for '03 Expedition with 4.6L vs. 5.4L engines (for 4x2 models)? Would I need a weight-distributing hitch (WDH) at lower weights for the 4.6 than the 5.4?
(1) Expedition brochure shows 5000 for 4.6 and 8950 for 5.4.
(2) Ford towing brochure shows several things:
(a) 6,050 for 4.6 and 8,900 for 5.4; and
(b) in another section, 6,000 w/o WDH, and 8,900 w/ WDH, with NO DISTINCTION for different engine sizes. My luck calling Ford for similar clarification in the past was unsuccessful (A: "Please ask Dealer"). Dealer was less than helpful today.
Assuming difference is about 6,000 vs. 8,900, what causes the difference? Is is something besides the 0.8L displacement increase? I have a loaded boat + trailer (towed infrequently) that goes about 6,000 and might want to get the 4.6L to keep from having to spend $2000+ to get the next higher model. Any explanations? Thanks in advance for any help you might have.
Old 07-05-2003, 02:19 AM
Colossus's Avatar
Colossus
Colossus is offline
Ask them to see if you can haul your boat on the test drive. Then make your decision.
Old 09-15-2003, 05:11 PM
anglerx's Avatar
anglerx
anglerx is offline
Thumbs down 2003 Expedition towing capacity: 4.6 vs. 5.4
Thanks, Collosus, but boat and dealer are far apart, and I'm not sure I could tell in a short test whether the 4.6 was overloaded or not.
Ford help line still unhelpful; anyone with expertise would be appreciated. Ford said they needed a VIN; otherwise, policy prevented them from disclosing towing capacity. Called back later with VIN, then they said "Research" could help only if I was the owner. Told them I was trying to make a buying decision based on towing capacity. Then they said Research would call me within 10 business days but no promises ... Tough way to sell cars. All I want to know is the towing capacity, with and without weight distributing hitch, for 4.6 and 5.4 models, and why there's a difference. Would also be nice but not critical to know what the cryptic "properly equipped" wording means.
Still hoping...
Old 09-15-2003, 07:25 PM
dtpatt2's Avatar
dtpatt2
dtpatt2 is offline
How big of boat? If in doubt, get the 5.4L. If you are towing something substantial, get the biggest, powerfullest you can afford...
Old 09-16-2003, 12:16 PM
jschira's Avatar
jschira
jschira is offline
Anything over 5000 lbs., you will want a WD hitch.
Amen to what was said above. When towing, there is no such thing as too much HP or torque. Get the nastiest engine that you can.
Old 09-17-2003, 12:48 PM
robc10x's Avatar
robc10x
robc10x is offline
I have found the 5.4L to be barely adequate for towing anything over 4-5k lbs. It does fine on the flats, but loaded w/gear in the back as well as a trailer struggles in the mountains. Nothing too bad, but i've been at 4grand and barely able to maintain 55, but it's something I can live with.
If you tow a reasonable amount, spring for the 5.4.
Rob
Old 09-18-2003, 02:06 PM
ClydeSDale's Avatar
ClydeSDale
ClydeSDale is offline
For the difference in fuel mileage the 5.4 would be the obvious choice if you're going to do any towing to speak of.
Old 09-23-2003, 09:52 PM
RickM's Avatar
RickM
RickM is offline
ACtually,, the butt gears makes more difference than .8 liter. 3.73`s will pull 1500 more lbs than the 3.55`s
but yea.. add the wd hitch. I did with my 5200 lb boat/trailer and it made a big difference. tow rig has a 5.0l
Old 09-27-2003, 01:09 AM
proudcelt's Avatar
proudcelt
proudcelt is offline
Thumbs down
Have an 02 SuperCrew with the 5.4 and just towed a 6000 LB trailer from AZ to WA. On the flats of Utah and Nevada it was ok, and mileage was around 9. As soon as I hit any grades at all it was like an asthmatic old woman and mileage dropped to 6. I have added a K&N FIPK and Gibson exhaust. Not sure I could have climbed some of the mountains in Oregon and Washington if I hadn't.
If you're going to tow over 5000 Lbs for ANY distance and over ANY hills, scrap the Expedition and buy a crew cab SuperDuty with the PowerStroke. You'll have more power than you need as well as a truck that is DESIGNED to tow and haul. Expeditions were designed to haul kids to soccer and groceries to the house. Another thing of note is the overall strength of frame and suspension when towing. Again, the tremendous strain placed on the tow vehicle is what the SuperDuty was designed for. Over 5000 Lbs you should ALWAYS use a load leveling hitch of some sort, and hopefully your boat trailer is equipped with surge brakes. Remember, when you're towing there's a big red sign on the front of your rig that invites every idiot on the road to pull in front of you and hit their brakes.
Old 09-27-2003, 01:13 AM
Colossus's Avatar
Colossus
Colossus is offline
FIPK's are junk. They just let hot air get into the engine.
I live in Washington, and that's why I won't have anything less than a 7.5L 460.
Old 09-27-2003, 09:50 PM
proudcelt's Avatar
proudcelt
Colossus, I agree with you for your truck. However, try this. Get a straw and try to breath through it while you are running up hill. That's what the new engine designs coming out of Detroit are like. The FIPK has added noticeable power and mpg increase for my '02 5.4L. Gotta compare apples to apples.
BTW, I'd give my eye teeth if Ford would start selling a truck with a good ole high cube engine like they used to build. Had a '77 F350 with the 460 and a granny gear, and that thing could pull your house up the side of a mountain at idle.
Old 09-29-2003, 06:00 PM
dtpatt2's Avatar
dtpatt2
dtpatt2 is offline
proudcelt,
I agree with the FIPK. Colossus is right about the hot air, but even if it's hot air, it's getting a crap load more than what it was. I had a '99 Expy, put on a FIPK and the engine was a different engine. The thing wasn't gasping for air anymore.
Back to the question, the 5.4L would handle a 5k boat, but the problem is, in my opinion, the suspension. I towed a 2250l. boat with mine and it was a stinkin yoyo in the back. Definitely get some sort of air bags or something that will help stiffin the ride when hauling the boat...
grpark20
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
39
07-06-2017 10:19 PM
keyul
19
03-28-2017 03:22 PM
astepatatime
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
17
02-21-2016 10:32 AM
FordmanNJ
15
08-30-2015 05:33 PM
joeyo67
02-01-2012 01:52 PM
Quick Reply: 2003 Expedition towing capacity: 4.6 vs. 5.4
