6.2L V8 Discuss the 6.2L V8
Timbrens
Old 04-20-2014, 07:29 PM
Flatbed Ed's Avatar
Flatbed Ed
Flatbed Ed is offline
Timbrens
Installed some Timbrens(the H.D ones) on my 2012 F-350 chassis cab on the rear a few weeks ago. They were easy to install and work well. $288 from Stengel Bros. They gave me a discounted price saying it should cost no more than a Dodge application. Could not install the 1 inch spacers as there was no room to do so. Even without the spacers, it holds weight very well. I have put up to 6400 lbs on the truck and it barely engages the overload spring. My 2012 350 can handle as much weight as my 1999 450! ( even without the Timbrens).
It would not surprise me if it could hold up to 10,000 lbs. cause I have had 7400 lbs on it in the past(without the Timbrens). I won't put over 8500 on it for safety reasons. And no the Timbrens do not engage when I hit a bump or dip on the road. I don't even know they are there till I load it up. They engage at about 4000 lbs. Once loaded, they reduce sway and squatting.
So far no issues and don't expect any.
Old 04-20-2014, 07:36 PM
ATP Pilot's Avatar
ATP Pilot
ATP Pilot is offline
keep us posted. Had them on my old truck, Nissan Titan, and was very happy with them.
Old 04-21-2014, 09:03 AM
tjcprop's Avatar
tjcprop
tjcprop is offline
My mechanic installed these on my 150 front and back with extensions to accommodate for the 9inch lift. This sure helps with the front from sagging with a plow added and when towing.
Old 05-18-2014, 10:02 PM
Flatbed Ed's Avatar
Flatbed Ed
Just an update. I put 8330 lbs. on the truck the other day. Did not squat and all was well.
Old 05-19-2014, 07:27 AM
jimmac28's Avatar
jimmac28
jimmac28 is offline
I installed Timbrens on my 2011 F250 what a nice ride, I pull a fiver with about 2500lb tongue weight, I didn't notice any squat.
But I also put on Bilstein's so I got the best of both worlds.
Old 05-19-2014, 08:59 AM
Big Vic's Avatar
Big Vic
Big Vic is offline
Love the Timbrens on my 2014 F-250. Unloaded ride is stock, since the springs sit about 1" above the axle. When loaded with camping gear in the truck bed and my 900 lb tongue weight TT, the Timbrens assist the stock suspension to inhibit porpoising, roll and sway. Makes my 250 feel like a dually 350 when loaded!
Old 05-19-2014, 09:22 AM
tjcprop's Avatar
tjcprop
tjcprop is offline
Great explanation. Have these installed on both my trucks for plowing & towing
MsLola
Slide-in / Truck Campers
25
05-04-2024 10:33 AM
Timtanium
2017+ Super Duty
11-18-2018 08:14 PM
LabCab
6.7L Power Stroke Diesel
12-30-2016 03:40 PM
JandC
73
12-12-2014 08:38 AM
zelnar
Fifth Wheel & Gooseneck RV Towing
03-01-2002 09:10 PM
Quick Reply: Timbrens
