I pulled a dash wiring harness from a 93 and it also has the RABS computer. How do I identify this computer to know if I can use it on my truck? Will any RABS work?
According to my books, '93 was change to RABSII module numbers begin with F3TF-2CO18 or F3UF-2CO18 other module numbers are RABSI. Doesn't appear that they will interchange.
I guess what confuses me is where it says single rear wheel only. And I did visually verify the RABS valve on my truck is the same as what I pulled from the same truck I got the harness from
