Oil leak location iDENTification
Been getting decent puddle 4"x4" under the 78 2wd 351W (swapped) with a c6 the puddle seems to right under where the trans and block meet at the passenger side of trans right under the bolt at bottom side of trans case Rear main seal?? Or is there anything on the rear passenger side of a 351w that could leak. I thought maybe intake manifold gasket but replaced that already and still leaking.
First clean the motor and transmission.... Then there's stuff you can apply on the suspected areas. Wait a day or two and check. I'm not sure 100% but I have heard from baby louder or a white powder spray. But that's how I look for mystery leaks. Also pull the dipsticks of transmission and engine and compare them to the oil on the floor. Don't forget the power steering.
FourxFour84
12-14-2011 04:08 PM
