Edelbrock carb not returning to idle?
Old 04-18-2014, 10:38 AM
bigdan1979f-250's Avatar
bigdan1979f-250
bigdan1979f-250 is offline
Have a 600 com Edelbrock 1405 carb I am having some issues with. Any time I gradually bring up the rpms and then take my foot off of the gas pedal, it stays at whatever rpm it was at before taking my foot off the gas. I can then tap the gas pedal and the motor returns to idle. It is manual choke(which I have disabled and wired the linkage to keep the butterfly open). My question is what would cause this to happen, something internal? The only other thing I can think is that my return spring(spring that pulls the throttle against the idle adjusting screw when you take your foot off the gas) is not strong enough. Any ideas?
Old 04-20-2014, 09:48 AM
hotstuff's Avatar
hotstuff
hotstuff is offline
incorrect alignment of throttle cable , on the pass side there is a clearance of .040 on the throttle shaft tang , my last idea would be slop in the throttle shaft . Good luck
Old 04-29-2014, 01:48 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Could be a weak spring or the throttle plates could be hanging on some kind of build-up on the throttlebody plate. it could also be what hotstuff said above.
Old 05-15-2014, 05:54 PM
bigdan1979f-250
Thanks guys, putting on a stronger idle return spring fixed it.
mihnen
02-05-2018 07:11 PM
F350dog
10-18-2015 08:52 PM
hwsykes
03-04-2007 08:24 PM
hotbbb
01-30-2004 03:12 PM
Duran7
06-03-2003 07:34 PM
Quick Reply: Edelbrock carb not returning to idle?
