Of coarse once over sized tires were installed on my 150 the speedo is off. Not a problem as I use the speedo on the installed Edge programmer. Was wondering if there was a way to correct the speedo inside instrument cluster or if I must have this done at a speciality garage.
Your edge programmer will correct it. It's been a while since I did it, but I know it can be done. It well also help your shift points and mpg's once the tranny knows how big your tires are and what gears you run
Correct that the speedo in the Edge unit reads correct. The dash speedo is off like 10-15km/h at 90km/h. So the Edge programmer has the ability to correct the dash speedo???
Are you sure you selected "save previous settings" when you were making the change[s] in the Edge? Double check the tire/wheel/gear ratio settings... It should correct the dash too.
As I wrote earlier, if these settings were not correctly added. The Edge would not be giving an accurate reading.
