Fan for my 52 F5
Old 04-23-2014, 08:45 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
I'm running a Car 3-blade fan with shroud and have had no issues even in 100 deg weather. But I have spent a lot of time getting my block and radiator really clean.
Old 04-24-2014, 12:15 AM
gearhead1952's Avatar
gearhead1952
gearhead1952 is offline
I have a four blade from an f1 and one from an f6. I need to look again but pretty sure the f6 fan has more than 4 blades
Old 04-24-2014, 10:44 AM
ALBUQ F-1's Avatar
ALBUQ F-1
There was a thread about this about 6 months ago if you want a good discussion of it.
https://www.ford-trucks.com/forums/1...-question.html
Old 05-06-2014, 09:42 PM
Joshua Farm's Avatar
Joshua Farm
Joshua Farm is offline
Anyone know size bolts?
Does anyone know the size bolts? I have located a matching 5 blade and have the metal ring, but no bolts to mount it on the hub.
Originally Posted by harleymsn
The parts book actually calls for a 5 blade (18.5" dia) part# B7Q8600C. The parts book shows ONLY 5 blade fans for all trucks 1948-56, so I wonder if the 4 blade was supposed to be on the passenger cars.
38 Coupe, I see you changed the pic you posted, where was that one from, as it indicated the fan part # to be 8602?
Anyhow, Part #B7Q8600c
Dennis Carpenter has 2 NOS
Klimesh Motor Sales Calmar, IA 52132 has 2
Miller Obsolete Binghamton, NY has 1 $90.00
Old 05-07-2014, 07:49 AM
harleymsn's Avatar
harleymsn
harleymsn is offline
8 No. 12-32 x 1/16"
Old 05-08-2014, 11:16 PM
Joshua Farm
8 No. 12-32 x 1/16"
Thank you, but I am measuring 1/4 " holes by 28 fine thread. Does that sound right? Are you saying that the screws are only supposed to be 1/16" long?
Old 05-08-2014, 11:18 PM
Joshua Farm
8 No. 12-32 x 1/16"
Am I reading this right? 1/16" long?
Old 05-08-2014, 11:22 PM
Joshua Farm
1/16" long? I measure 1/4" diameter and 28 fine thread. I have another problem. The pulley for the fan is freely sliding from mounting hub. Is it supposed to do that? If not, how do I fix it?
Old 05-08-2014, 11:26 PM
harleymsn's Avatar
harleymsn
I'm sorry, they are 1-1/16th
Old 05-08-2014, 11:31 PM
Joshua Farm
No problem, thank you so much for the specs. I could not find them anywhere. Do I have a major problem with the pulley? It slides freely from behind the mounting ring aft to the motor on the shaft. Something just doesn't seem right with this?
Old 05-08-2014, 11:38 PM
harleymsn's Avatar
harleymsn
Here is the list of screws and bolts for the assembly
EDIT: Just relooking at the chart, the 48-51 Big Job 337 fan hub had 1/4 x 28 thread x 3/4". Maybe somebody changed out the hub before, if so the parts list is just above the second group highlighted. I edited the picture.
Old 05-09-2014, 06:42 AM
Joshua Farm
I think your right, because it is a 239 and it had an electric fan on it. The pulley behind the hub is not firmly attached to the shaft. It does stop turning when I hold it up close to the back of the hub. It does look like there is a gasket between it and the hub.
  #28
Old 05-09-2014, 11:31 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The fans on these are opposite from most modern setups. The shaft is held firm, and the pulley/hub/fan spin on that.
  #29
Old 07-15-2014, 09:12 AM
Joshua Farm
I understand the spinning freely, but it slides back and forth along the shaft. The last thing I want to do is to put a belt on and throw the fan. It looks like there is a sleeve or something missing to hold it firmly on the shaft.
  #30
Old 07-15-2014, 09:32 AM
Joshua Farm
Yes, but the pulley is not held firm. It slides forward and back on shaft
Quick Reply: Fan for my 52 F5
