64 4x4 brake line mess
Old 04-14-2014, 10:27 PM
64highboy's Avatar
64highboy
64highboy is offline
Need help cleaning this mess up. I would like to get away from all these adapters. Is there a master I can bolt on that will accept the same fittings as the wheel cylinders and rubber brake lines.
http://i1229.photobucket.com/albums/.../imagejpg2.jpg
http://i1229.photobucket.com/albums/.../imagejpg1.jpg
Old 04-15-2014, 02:12 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
As original:
Old 04-15-2014, 08:33 AM
crazed87bronco's Avatar
crazed87bronco
crazed87bronco is offline
Have you tried going to the parts store to see if they have any fittings and or brake line you could try to delete some of the adapters so you don't have as many places for potential leaks.
Old 04-15-2014, 09:43 AM
bertha66's Avatar
bertha66
bertha66 is offline
I see in your pictures that the MC has been changed to a double; and one of the extra fittings is for the brake lights. To get rid of that set of fittings; get a brake light switch that mounts on the pedal and does not work off the brake pressure. Look at a mid 70's truck brake pedal. My son and I did his F100 2wd this way by changing out a pedel from my 73 parts truck.
abrauer
07-09-2012 02:52 PM
Dancingchicken
07-03-2009 11:07 PM
BroncoII85
Bronco II
01-23-2006 09:52 PM
caine95
General Automotive Discussion
10-16-2004 08:36 PM
turbozeke418
1978 - 1996 Big Bronco
01-17-2004 03:55 PM
Quick Reply: 64 4x4 brake line mess
