Exhaust idea
Exhaust idea
Ok so did a 351w swap and installed short tube headers on it now the exhaust don't fit so I figured I might as well just get the exhaust done my way now. I thinking either straight pipes with megaphone exhaust tips or glass packs with megaphone exhaust tips. I have no idea how you size megaphone tips like I want to where it opens up to like 5in does anyone have any experience with megaphones I know it is extremely rare nowadays. What is your guys opinion?
true duals also doesnt really flow correctly due to the all the bends getting around the Tcase.
Run a customer built Y pipe or Bassani Y pipe, Hi flow cat and 3" exhaust running stock location which you can then split to a dual look if you so wish. I run a hooker Aerochamber muffler which has a nice tone when cruising and wakes up well when on the skinny peddle.
on
It seems all the kids these days want these massive big exhaust tips. I don't get it but it has little or no effect on how the system performs so you can pretty much do whatever you like.
Matthew.....if you run pipes out the back of an SUV, you can get exhaust fumes entering the vehicle from the back window. If you want the megaphones, angle them to the sides behind the rear tires. I've seen them run out the back, but it's not worth the risk of sucking exhaust fumes!
on
It comes from the old carbed engine days, those fueling devices have no way of self adjusting to the relatively large changes in fuel requirements that occur when a restrictive exhaust is opened up. EFI on the other hand is designed to continually self adjust to a variety of operating conditions including temperature, air pressure, altitude, and changes in the exhaust system as it ages and deteriorates. Basically as long as the O2 sensor remains in the exhaust system and connected to the computer there is no way to burn a valve or otherwise damage an EFI motor with exhaust changes.
And with all the backpressure straightened out, looks like I'm looking for a new exhaust man.
Because the dead air vortex behind the truck while it is moving pulls the exhaust into the cabin either through the open back glass or (and this happens whether the glass is open or closed) the weep holes in the tailgate. No stock Bronco has the exhaust exit out the back for this reason. I suppose if you enjoy the dull throbbing headache that exhaust fumes give you just before you pass out, it would be worth a try though.
