Keeping the radio powered during between ACC/ON/Start?
I'm sitting in my long ignored truck yesterday after a bike ride, and had this experience:
Key to ACC - Kenwood radio boots and I listen to the radio while loading my bike, changing clothes, etc. Get in the truck.
Key to ON - Radio reboots. WTS light goes out after 10-15 seconds.
Key to Start - Radio reboots. Another little piece of me dies...
Is there any way to run power to the radio through something that will buffer the power long enough to keep the radio running during these normal key cycles? It's not a big deal with the stock radio, but these Kenwood's run Windows under the covers, and take forever to reboot.
Mark
Mark
Mark
Big-amplifier enthusiasts put great big capacitors on their power line (with a diode to prevent the truck from using the capacitor power). There is also a timed power, to allow the windows to roll up before opening the door (key off). Maybe a visit to the wiring diagram will yield a clue on that one.
The capacitor and diode that Rich mentioned is a far-better solution.
The battery will just go dead a couple hours after he turns the truck off, and eventually become a maintenance item.
The capacitor will just discharge, awaiting a re-charge "next time".
Capacitors are meant to get past "transients". Batteries are meant to supply power.
Pop
I don't know because I'm too lazy to try to figure it out, but with a powerful radio, say 100 watt, that does a buncha' other things...it may be drawing up to 10 amps for the coupla' three seconds your starting say in the winter. With a 20a/h battery, I know that won't drop down much. I wonder how hefty of a catalytic cap you'd need to sustain that current supply for that 2 or 3 secs? Or how sensitive the radio is to voltage variance?
I'm not sure the capacitor idea will work. From what I read, they need to have constant power input to work, so you couldn't wire one into the existing radio power circuit. It could be connected to constant voltage, but that's the same as wiring the radio to constant voltage.
I did find this regulator, designed for the car PC market, that might be just the ticket. It has way more functionality than required to keep a radio running, but I think it would work.
Mark
Mark
