99 F-150 Brake Lines
Hello,
I have a 1999 Ford F-150 4X4 w/4.6L V8 W code, I recently lost all brakes. The primary line from Master Cylinder to ABS Pump rusted out completely. Replaced them but the other lines from ABS Pump to wheels are looking real bad. So I need to replace them, however I have no idea what the routing system looks like. Does anyone have access to a 97-03 F-150 Brake Line Diagram? I live at the jersey shore... so yeah rust is extremely common.... unfortunately.. Please help. Also if anyone knows where to get line assemblies? Thank You.
Inline Tube sells complete brake line kits, pre-bent with fittings, etc.
Inline tube The brake plumbing experts
I don't know if you are still working on this problem or not, but I am having all of the brake lines in my truck swapped due to rust and bad shade tree work.
I am having them all made in straight tube and am going to bend then myself and have the fittings already put on.
When I am complete next weekend I'll link you to the process if you need ut.
Cheers
Cheers
I did the replacement rubber lines from the local place and bought 3/16" line coil to bend my own. The tube nuts are 3/8-24 at the rubber ends of the steel lines and metric at the ABS end. Rear axle also has 3/8-24 tube nuts on the ends of the steel lines. I'm not sure what the metric tube nuts were cause I was able to reuse those.
bbsitum
1997 - 2003 F150
09-20-2013 01:11 PM
