EcoBoost (all engine sizes) 3.5L Twin Turbo EcoBoost V6, 2.7 Twin Turbo EcoBoost V6, 2.3l/2.0L I4 EcoBoost Engines
First Tow with the Eco Boost
Old 02-16-2014, 12:21 PM
Brandon D's Avatar
Brandon D
Brandon D is offline
Lead Foot User
Drove down to MN on Thurs to pick up a new camper I bought. Trailer is 8000lbs and 34ft and the truck handled it surprisingly well. I got 17 MPG on the 1100km trip down and averaged 7.5 MPG on the trip home. All in all it towed better than I thought it would but I still miss my F350 for jobs like that!!
Old 02-22-2014, 08:32 AM
keyston44's Avatar
keyston44
keyston44 is offline
Did the trailer flatten out the springs much? Did the weight distributing hitch level it out well?
When I had a trailer like that it almost completely squished my 2000 F250. I had to add the air bellows to level the truck out.
Key
Old 02-24-2014, 10:18 PM
Brandon D's Avatar
Brandon D
Lead Foot User
The trailer did squat the back end down quite a bit but the load leveller hitch helped tremendously. It sat damn near level once we got that hooked up. To be honest I fully expected it to squat a lot more than it did.
Old 03-01-2014, 06:38 PM
EcoboostKev's Avatar
EcoboostKev
EcoboostKev is offline
Nice looking setup! What gears do you have?? You should look into getting the telescoping tow mirrors. Much nicer for towing...
Old 03-06-2014, 06:46 PM
Brandon D's Avatar
Brandon D
Lead Foot User
Thanks! I've got the 3.55 gears and I would get the mirrors but I won't be towing the trailer much. Most likely to a lot at the lake and then leave it there. I'd definitely need an F350 again if I planned on towing it all the time!!
Old 03-24-2014, 09:24 PM
conger's Avatar
conger
conger is offline
Check out etrailer.com I've got those snap on tow mirrors and they look and work great. I'm not a fan of the big mirrors on my F150 they just look to large on a non lifted truck.
Old 04-03-2014, 10:44 PM
Brandon D's Avatar
Brandon D
Lead Foot User
Thanks conger, I already have a set of strap on mirrors that I use. They're not perfect but they work good enough for the small amount I'll be towing this trailer. Cheers
Old 04-04-2014, 12:00 PM
Torklift Sheryl's Avatar
Torklift Sheryl
Torklift Sheryl is offline
SPONSOR
These trucks sure do great towing! I just wanted to add a suggestion for a suspension upgrade with Torklift StableLoads.
They are going to greatly reduce side to side sway, sag and trailer bounce. It also easily disengages when you're not towing and will make your ride much smoother.
-Torklift Jen
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Rickyrobert
2009 - 2014 F150
20
04-11-2015 04:19 PM
rainbow stu
2009 - 2014 F150
29
05-03-2013 07:26 PM
the_justin
1999 to 2016 Super Duty
34
04-28-2010 08:23 AM
mrad
02-21-2010 06:57 PM
tdford
Slide-in / Truck Campers
12-21-2004 09:34 PM
Quick Reply: First Tow with the Eco Boost
