Overflow tank antifreeze
I changed the water pump on a 4.9 88 F150.
I had to open the overflow tank a couple of times to fill it with antifreeze.
Its right at the cold mark,
but,
I cleaned off the top of the tank because there was antifreeze on top of the reservoir.
it seems like antifreeze is coming up from the antifreeze tank/reservoir, or when I go over bumps the cap is bad and allowing antifreeze to pass over the seal and get on top of the tank.
anyone changed a reservoir recently because of this? I see a couple online for cheap and one with a one year guarantee.
but,
but,
but,
My reservoir is a 20 oz Arizona Southern Style Sweet Tea bottle with a hole drilled in the cap the same diameter as the overflow hose that runs to the bottom of it, and a small hole next to it for a vent. If you ain't ever held one of these bottles... it's just as sturdy as can be, and I have zero spillage.
I still need to get a clamp and mount it permanently. I should take the label off and paint it black too.
gasket
I was thinking about taking a tire tube or something a cutting out a circular gasket and put under the cap to make a seal.
or some type of tape that is resistant to antifreeze to try and keep the antifreeze inside the overflow.
have you ever replaced the reservoir on your truck??
BigBrent
04-29-2014 01:45 PM
Mervy49
12-27-2012 10:07 AM
