Hi all. Trying to find out if my 60 is from a Ford or Dodge. Original rear went bad on previous owner. He replaced it with who knows what. Is there any differences between the dodge or Ford 60's? The info tag is missing. There are no #'s located on the axle tubes. Only #'s I can find are on the center housing. Leaf spring pads and shock mounts fit my highboy.
I wire brushed the right side. Will dig deeper. I bought a Dana 60 rebuild kit for a Ford. I'm hoping it will fit this rear end. I guess I won't know until I tear into it.
As far as rebuild kits, the center stuff is the same, but there are a few, weird ones out there the had different outer bearings, and a few minor other things. Most likely, the kit you got will be fine.
