new IP, Intermittant no start.
92 ford e350 clubwagon 7.3 idi E40d
370,000kms (canada)
New GP's and Controller
i just got a new IP installed by a shop the next town over.
the van has been running great. like a bat outta hell. but twice now I've gone down to start it up when its already hot. and it won't start. just cranks and cranks, no smoke coming from the exhaust while cranking either. i cracked all the injector lines and theres fuel spraying out of them all. so it should be all bled up. but nothing. will not fire.
could it be a pump timing issue?? the engine does sound different to how it used to run before the new IP was installed.
even after leaving it over night it will normally fire right up in the morning. so unless it has a weird intermittent air leak??
what else should i be checking??
370,000kms (canada)
x2 and pulling the test from another recent thread:
I'd bring it back to the shop to get it replaced again. I can't remember exactly what the issue is, but I think it has to do with warn out parts in the pump not building enough pressure when warm, but works fine when cold. That or the fuel shut off solenoid?
I bought my IP and all 8 injectors from Napa on my '89, and I had two injectors fail within 300 miles, and I have another one that leaks out, but it's my dad's truck now so it's his to fix :P I'd say Napa's remanned stuff is hit and miss, their exchange policy is pretty good though as long as you have the receipt.
540milotalon
09-18-2010 11:28 AM
roadbike21
07-29-2006 02:14 PM
loneoak
09-20-2003 04:44 PM
