Back up lights
Back up lights
The PO put post 66 tailights in our 66 and it has the capacity for backup lights. Our truck also has a 73 C6 and so I believe has the back-up light neutral safety switch on the tranny. Can anyone point me to a wiring diagram that would show the set up? My 66 diagram of course does not have backup lights diagrammed. Thanks for the help
1978/79 F100/250 with C4's use a different NSS than F100/350 with C6's. Both NSS's are located on the transmission.
Bill, what would that column mounted NSS look like? Never noticed anything unusual on the column and I have NSS function. WOuld the backup lights work from that NSS switch. There is definitely a switch of some sort on the passenger side of the C6. This truck is a real frankenstein. The C6 could be a later model.
1967 was the first year that backup lights were available for trucks, Bronco's and Econolines.
1967/72 F100/350 Styleside tail lamps that have the backup lamp lenses encompassed within the tail lamp lenses can be installed in 1964/66 F100/250 2WD & 1966 F100 4WD Stylesides.
The NSS selector lever attaches to the shift tube thru a hole in the steering column shroud. Its knife blade end fits into the NSS.
The lever is the same 1965/77 F100/350, so if your truck has an A/T, it's already present.
RobsOld72
10-08-2010 06:32 AM
fordinterceptor
11-08-2009 09:35 AM
salf100
08-06-2009 01:11 PM
02-09-2001 11:35 AM
