Sponsored by: Halo Lifts
New F150 Survives Ovens, Freezes and Salt
Old 04-10-2014, 09:26 PM
FishOnOne's Avatar
FishOnOne
FishOnOne is offline
Received 1,449 Likes on 894 Posts
Here's a new video... Maybe some can rest a bit better now.
Old 04-10-2014, 09:45 PM
2ndStroke's Avatar
2ndStroke
2ndStroke is offline
I was worried about how it would hold up to acid, phew, I can sleep good tonight
Just kiddin, great video
Old 04-10-2014, 10:09 PM
paredneck33's Avatar
paredneck33
paredneck33 is offline
Yeah that's a great video. I just wonder when they will release the actual ratings for this truck. Also I found it interesting that Ford has been using the Davis Dam area for tow test for over 30 years. And that is the place of choice for the new standardized tow tests that all the manufactures will be required to use. That bit of info should shut those TFL idiots up.
Old 04-10-2014, 10:39 PM
RigTrash601's Avatar
RigTrash601
RigTrash601 is offline
You're saying the other guys may have to "put up, or shut up?!! UH-OH
Old 04-10-2014, 11:11 PM
CuNmUdF250's Avatar
CuNmUdF250
CuNmUdF250 is offline
Watch the 2015 F-150 survive ovens, freezers and salt. With some acid thrown in. - YouTube
how I`m gonna rest better.... now I`m stressed thinking about how I have to convince my wife we need this truck!!!!
Old 04-10-2014, 11:18 PM
RigTrash601
Better to ask forgiveness than permission!
Old 04-11-2014, 01:31 AM
CGiron's Avatar
CGiron
CGiron is offline
Good torque
Ford has not revealed the horsepower or torque specs for this new engine, which was designed from the outset to be equipped with automatic start/stop technology. But I just witnessed this engine on a dynamometer at Ford’s testing centre in Michigan as it ramped up from idle to full throttle and stayed there. It didn’t take long for the twin turbos and exhaust to start glowing red from the heat, but more interesting was the torque figure on the computer in the control room: 345 lb.-ft. from 2,500 to 4,500 rpm, which is right in the sweet spot where power is needed — and more than the current 3.7-litre V6, while only slightly less than the 380 lb.-ft. in the 5.0-litre V8.
Ford engineers try their best to break new F-150 | Driving
Old 04-11-2014, 05:59 AM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,222 Likes on 804 Posts
Cool vid, thanks for sharing! I'll wager t hat some of these clips make it to the initial set of infomercials that Ford will use when she finally starts coming out.
Old 04-11-2014, 10:15 PM
CuNmUdF250's Avatar
CuNmUdF250
cant wait for this truck.....I wont be the first to get one but I`m already considering it a done deal
Old 04-11-2014, 10:38 PM
RigTrash601
Which engine setup are you leaning towards? I would imagine, with the lighter truck, the 3.5L EB will be something to behold!
Old 04-12-2014, 12:40 AM
CuNmUdF250's Avatar
CuNmUdF250
honestly just imagining my `13 700lbs lighter makes me think the 5.0 will be the ticket.....but I`ve never driven a ecoboost....for my purpose however more economical is better so most likely 5.0 since its cheaper and gets better mpgs.....will be buying used though hence the reason for not being one of the first to get one
Old 04-12-2014, 07:54 AM
RigTrash601
No doubt, I've only ridden in a EB powered 150, never driven one. It's impressive, but the V-8 rumble of the 5.0L, who needs a radio?!!
Old 04-13-2014, 11:21 PM
Soko179's Avatar
Soko179
Soko179 is offline
Thanks for the video and I can't wait to get behind the wheel of one. Now if they would let us know the towing specs.
Old 04-14-2014, 09:25 AM
fordman19762003's Avatar
fordman19762003
fordman19762003 is offline
I hate to be the one negative person here, but I'll believe all of the claims after the new truck has been on the road for a couple of years. Every time a new model comes out the manufacturer claims it was torture tested for "X" amount of miles without any problems. But, after the production models hit the roads most of the time problems arise that should've shown up in the testing(ie. cam phaser knock,vibrations, ect.).
The new F150 is looking better every time I see one, but I'm not going to get too excited just yet.
Old 04-14-2014, 09:34 AM
RigTrash601
I'm definetly "smelling what ya stepping in cuz" I won't buy the 1st generation of a new series of anything. (so far anyway) I'll let them get the "bugs" worked out first.
Quick Reply: New F150 Survives Ovens, Freezes and Salt
