New F150 Survives Ovens, Freezes and Salt
Here's a new video... Maybe some can rest a bit better now.
I was worried about how it would hold up to acid, phew, I can sleep good tonight :)
Just kiddin, great video |
Yeah that's a great video. I just wonder when they will release the actual ratings for this truck. Also I found it interesting that Ford has been using the Davis Dam area for tow test for over 30 years. And that is the place of choice for the new standardized tow tests that all the manufactures will be required to use. That bit of info should shut those TFL idiots up. :-X04:-jammin
Originally Posted by paredneck33
(Post 14251200)
Originally Posted by Troy Buenger
(Post 14251036)
Watch the 2015 F-150 survive ovens, freezers and salt. With some acid thrown in. - YouTube |
Originally Posted by CuNmUdF250
(Post 14251347)
how I`m gonna rest better.... now I`m stressed thinking about how I have to convince my wife we need this truck!!!!:-X19 :-X04
Good torque
Ford has not revealed the horsepower or torque specs for this new engine, which was designed from the outset to be equipped with automatic start/stop technology. But I just witnessed this engine on a dynamometer at Ford’s testing centre in Michigan as it ramped up from idle to full throttle and stayed there. It didn’t take long for the twin turbos and exhaust to start glowing red from the heat, but more interesting was the torque figure on the computer in the control room: 345 lb.-ft. from 2,500 to 4,500 rpm, which is right in the sweet spot where power is needed — and more than the current 3.7-litre V6, while only slightly less than the 380 lb.-ft. in the 5.0-litre V8.
Ford engineers try their best to break new F-150 | Driving :-X22 |
Cool vid, thanks for sharing! I'll wager t hat some of these clips make it to the initial set of infomercials that Ford will use when she finally starts coming out.
cant wait for this truck.....I wont be the first to get one but I`m already considering it a done deal :-X20
(Post 14253847)
honestly just imagining my `13 700lbs lighter makes me think the 5.0 will be the ticket.....but I`ve never driven a ecoboost....for my purpose however more economical is better so most likely 5.0 since its cheaper and gets better mpgs.....will be buying used though hence the reason for not being one of the first to get one
(Post 14254121)
Thanks for the video and I can't wait to get behind the wheel of one. Now if they would let us know the towing specs. :-wink
I hate to be the one negative person here, but I'll believe all of the claims after the new truck has been on the road for a couple of years. Every time a new model comes out the manufacturer claims it was torture tested for "X" amount of miles without any problems. But, after the production models hit the roads most of the time problems arise that should've shown up in the testing(ie. cam phaser knock,vibrations, ect.).
The new F150 is looking better every time I see one, but I'm not going to get too excited just yet. |
Originally Posted by fordman19762003
(Post 14259856)
