1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
2007+ Front Window Regulator Replacement
Old 04-01-2014, 12:29 PM
makuloco2000's Avatar
makuloco2000
makuloco2000 is offline
This has been a long time coming and I finally got one in and had time to record just how to replace the front window regulator on the 2007+ Expeditions and Navigators. This is an all too common issue and if you own one of these this will haunt you sooner than later. In this video I walk you through the procedure. Hope this helps.
vwilcox27
11-20-2018 10:33 AM
KG Excursion
07-26-2016 02:11 PM
SpankF100
01-06-2005 10:12 PM
caseyatthebat1
02-11-2002 05:01 PM
Quick Reply: 2007+ Front Window Regulator Replacement
