1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
bed drain holes - why not?
Old 03-31-2014, 03:36 PM
speakerfritz's Avatar
speakerfritz
speakerfritz is offline
I have a 2005 f-250 CC with a plastic bed liner. I'm getting the sense that the bed itself is not draining since when I pull out after a rain storm...a heck of a lot of water hits the black top.
Perhaps under the plastic bed liner, there was a previous spray on or other liner solution and possibly clogged what ever is intended to provide drainage.
so google around on this subject and the playing field is divided....
some say no drain holes are needed since there are gaps in the assembly and water can get out thru the gaps.
others point to rubber capped holes about an inch above the water line and say those are the drains (the caps look like a quarter in size).
so at this point, it looks like its time to pull out the drill and identify 2 low spots near the front of the bed corners that are not in the proximaty of gas tanks, electrical harnesses, brake lines, fuel lines, fuel vents, bed cross bracing, etc...and drill two holes.
so rather than be told after the fact why I should not drill these holes, by all means, tell me now before I do so.
thanks
Old 03-31-2014, 03:40 PM
1buzzbait's Avatar
1buzzbait
1buzzbait is offline
uh-i would pull the pos plastic liner out and clean where the floor of the bed meets the back of the bed (below the rear vision) that is your drain slots and can get clogged w/debris. this of course wont stop the pos plastic liner from filling w/water and sloshing out w/accel from a stop.
Old 03-31-2014, 03:49 PM
r2millers's Avatar
r2millers
r2millers is offline
Yow. At first I thought this question was about old folks homes and the bedpan possibilities.
I feel much better now.
Old 03-31-2014, 03:59 PM
1buzzbait's Avatar
1buzzbait
well i answered didin't I?
Old 03-31-2014, 05:09 PM
r2millers's Avatar
r2millers
Especially the slots getting clogged with debris!
Old 03-31-2014, 05:16 PM
V10man's Avatar
V10man
V10man is offline
I got a 5 gallon bucket of dirt/crap from under my pos bed liner. Best thing I ever did was take a sawzall to it and put in in the dumpster. lol
Old 03-31-2014, 05:20 PM
r2millers's Avatar
r2millers
Speaking of crap, I think we are really talking about bed pans, not liners here.
Does this qualify for hijacking?
Old 03-31-2014, 07:07 PM
1977cutcher's Avatar
1977cutcher
1977cutcher is offline
It is in my humble opinion that destroying beds is what bed liners do best. They vibrate while going down the road and in time wear the paint off. Water then gets behind it and starts rusting the now unprotedted metal.
Old 03-31-2014, 08:43 PM
speakerfritz
so yes...the forum was correct...we do not have to worry about our truck beds being so water proof that water will pool.
took a drill to the bed liner and drilled thru the liner til I hit the bed.....soon as the first hole opened....all the water in the bed pan gushed out onto the street.
the truck bed did not hold the water at all.
Old 04-01-2014, 04:28 AM
1buzzbait's Avatar
1buzzbait
well I would quickly make sure that you prep-paint any damage to the bed from the drill bit, rust has no mercy
Old 04-01-2014, 06:40 AM
jdadamsjr's Avatar
jdadamsjr
jdadamsjr is offline
the thing about drain holes is that is one more place for stuff to ENTER too !
I too vote to remove the plastic bed liner and repair any damage....
only joy I got from them was once armor oiling it in prep for selling the son's old Ranger and a few of his soccer buddies where showing off catapulting over the side into the bed and it was WORSE than ice when they landed - no injuries but lot's of laughs !
Old 04-01-2014, 01:56 PM
SteveH-CO's Avatar
SteveH-CO
SteveH-CO is offline
If you park outside and don't have a topper, you will always have condensate and moisture forming between the bed liner and bed. I doubt drilling hole in the liner will make this better or worse, but having 10 gal. of skanky rainwater in your bed can't be that much fun. If you have never removed the bed liner, you should do it. Apply a lot of wheel bearing grease to the bed surfaces that are rusty, and reinstall the liner. If it's been in there a while, it will have removed all that paint it ever will.
I put a rubber mat in the floor of my truck - I can remove it if I want a slippery bed for unloading mulch, or leave it in for a nonslip surface. I chopped up my plastic bedliner and made 'floor mats' for snow shovels out it. Plastic bed liner center sections make a nifty 'floor' for an offroad truck roof rack, too.
69-er
2015 - 2020 F150
15
11-02-2017 09:17 PM
408 Torquer
09-29-2016 04:34 PM
kawa
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
16
04-11-2010 12:13 PM
STJones
2004 - 2008 F150
07-18-2005 08:35 AM
mcookd
Aftermarket Products
04-22-2005 01:40 PM
Quick Reply: bed drain holes - why not?
