1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 11-19-2014, 07:49 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
Print Wikipost
Lifetime LED Headlights (Review)
Old 06-16-2014, 12:16 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Originally Posted by Trophy_23
These were a direct fit into the 05-07 headlights I take it?
Well yes, it's still a standard bulb base.
On my converted 02 there was a slight bit of grinding of the metal plate behind the headlight.
  #47
Old 06-16-2014, 04:22 PM
kjdavis's Avatar
kjdavis
kjdavis is offline
Yes sir, H13's. My truck is an 02 with the 05 headlights using the 99-04 header panel. I had to trim the panel a bit to clear the fan on the back of the bulb. If your truck is 05-07 you shouldnt have an issue.
  #48
Old 06-16-2014, 05:23 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
Ditto on me. 05-07 should fit no problem.
  #49
Old 06-16-2014, 05:24 PM
Trophy_23's Avatar
Trophy_23
Trophy_23 is offline
Thanks guys! I'll keep these in mind when I have one go out. It just doesn't fit the budget at the moment after doing studs/delete etc last week!
  #50
Old 06-16-2014, 05:37 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
I sort of like the LED idea.
The only problem around here is when it does
snow it's that wet stuff that sticks to everything
and then freezes hard. Wiper shakers come to
mind at times like that. I would not want to have
to go out every few miles and clean the headlights too.
Maybe someone will come up with headlight heaters
or a set of wipers with shakers to clear the lens.
Sean
  #51
Old 06-16-2014, 05:45 PM
02TB250's Avatar
02TB250
02TB250 is offline
Sean
I know that my LED cubes do not de-ice in the winter if I'm driving. My headlights with the HID projectors will. But after a few miles the LEDs are useless.
  #52
Old 06-16-2014, 07:38 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
I'm still happy with my Lifetime LED headlight bulbs. Not once have I wished I had my HID's back again, they were horrible. Plus, the Lifetime headlights match my LED light bars in my bumper, so that's a bonus.
I will second the fact that the 05-07 reflectors suck as they are side to side reflectors, not top and bottom like most vehicles. But, even with that I like the pattern they put out better than my HID's did.
Did you get the offset stuff fixed?
  #53
Old 09-18-2014, 08:24 PM
Trophy_23's Avatar
Trophy_23
Just checking back in, everyone still happy? I am thinking of pulling the trigger here pretty quick. Has anyone got them for their fog lights also?
  #54
Old 09-18-2014, 08:25 PM
acf6's Avatar
acf6
acf6 is offline
yup still bright as hell. these are getting very popular
  #55
Old 09-18-2014, 09:05 PM
xmontex4's Avatar
xmontex4
xmontex4 is offline
Throwijg thisbiut there dont get cheap ones on amazon... my passenger loght on my expy is leaking and my driver side is already out after a month. Also when using high beams the passenger side shuts off so with high beams on I have all ny lights off lol. Once I get something out of this company I bought them from I will be going with lifetime ones.
  #56
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
One of my retaining rings stripped so the bulb kept falling out. They sent me 2 new ones. No problems with the actual bulbs. Everyone that sees them likes them.
  #57
Old 09-18-2014, 09:07 PM
Trophy_23's Avatar
Trophy_23
Great to hear thanks! No I wouldn't go with Amazon ones, I would do Lifetime for sure. I am really curious about bulbs for the fog lights as well. No one has tried that?
  #58
Old 09-18-2014, 09:15 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
I've heard it doesn't work.
What I would do is put like amazon LED bulbs in the fogs. Not like the headlights but the ones that have the tower with a bunch oh LEDs all around. That way you get color match and good light.
  #59
Old 09-19-2014, 08:45 AM
HuntsDucks70's Avatar
HuntsDucks70
HuntsDucks70 is offline
This is accomplished with 1 LED for Low and 2 for high.
the set up is likely a cluster of small high power LEDs coated with phosphor, for what it's worth (likely not much)
  #60
Old 09-19-2014, 08:51 AM
HuntsDucks70
The way this is written (one person, one time) makes me feel like it is a tale. Given that these lights produce MORE heat than a normal bulb, and even have a fan, also make me thing its not true.
while it is true that LEDs generate a huge amount of heat, the heat is NOT thrown forward, thus the large heat-sink and fan behind the LED. based on my knowledge of LED function, i would have say that these guys are right and that they do not generate enough heat to thoroughly melt ice in said conditions.
Quick Reply: Lifetime LED Headlights (Review)
