351C headers that fit???
Check out Sanderson Headers; I've got a set of block huggers to put a Cleveland in my 64. They are very well made, the flanges are thicker than any others I've seen. They have several different styles of cleveland huggers, I bet one will fit Cleveland around your '65
a 65 should be a lot easier than 64 and earlier... at least you have modern motor-mounts... The headers are the hardest part, there aren't many people still makeing parts for the Clevelands
Which brings up the point that unless you already have a pile of Cleveland stuff laying around the house (I did...so I got stoopid) I'd look at the Windsor motors instead - after market heads flow just as well as the Clevie stuff (unless you want 4BBl heads, which are a total waste on the street) and the parts are a LOT cheaper and easier to find. They haven't made Clevelands in 30 years (God I'm old...)
by modern mounts I mean your truck will have two mounts on either side of the motor, and a third at the rear of the transmission. '64 and Earlier trucks had one mount slung under the damper pulleys and one at either side at the rear of the motor - the transmission dangled off in space.
As for what else you would have to do to make it work, that depends on what motor/transmission you have now and if the motor mounts and bellhousing are the same. You haven't posted enough info to answer that...
tazf250
06-27-2005 12:13 AM
tastyklair
07-28-2004 12:46 PM
