Broke stud off a Upper strut mount ?
Old 01-16-2018, 02:27 PM
Dead_goldstar's Avatar
Dead_goldstar
Dead_goldstar is offline
Trailering
Question Broke stud off a Upper strut mount ?
This is probably a redicioiis question but I broke 1 of the 3 studs off a Upper strut mount while I was using the torque ratchet. Is it possible to take it apart and just replace the broken bolt on it or am I having to go buy another upper strut mount. I heard people have done this just not sure if it’s worth it. I would like to hear your thoughts. Thanks
Old 01-16-2018, 09:07 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
im not familiar with this particular strut, but how about grinding it down flush and drilling thru the old stud / mount while still installed....... then put a new bolt and nut in the hole ? ....... if you have access to the bottom side.
Old 01-17-2018, 06:14 AM
Dead_goldstar
Trailering
I’ll give it a try
Hello I appreciate you taking the time and offering me a possible solution to my problem I’m going to give it a try worst case is I’ll have to purchase a new upper strut mount. Lesson learned don’t over torque those small bolts on a strut mount. Thanks again
Henrys son
10-15-2009 01:45 PM
SLAYER1
1999 to 2016 Super Duty
07-23-2007 02:35 PM
kcwelshans
08-18-2004 09:49 PM
oleblue70
05-19-2002 05:11 AM
Quick Reply: Broke stud off a Upper strut mount ?
