Which transmissions will fit. 1992 e4od 4x4
on
The reason I asked is because this trans is 100% computer controlled and many many people have it replaced or rebuilt only to find out it still does the same thing.. because the real problem was with a sensor or wiring.
If it turns out yours does need to be replaced then you will want an E4OD from a 4.9, 5.0, 5.8 truck of '89-94 vintage to be directly compatable, after that the solenoid pack was changed.
